Need advice on Handlebars---Contains all previous handlebar links
I did some research on the handlebars available for this bike so i have some idea at what im looking at.
The links provided are the ones i have found on here(ALL OF THEM)
Handlebar Recomendation
https://www.kawasakiforums.com/forum...hlight=mirrors
MSR handlebars
https://www.kawasakiforums.com/forum...ght=handlebars
Pro Taper SE handlebars...
Bent my handlebars. What should I Buy?
handlebars
why new bars?
Handlebar Recommendations
Need some help picking bars
BENT BARS ? GOOD REPLACEMENT #, size, brand etc.
https://www.kawasakiforums.com/forum...ead.php?t=5730
-=Bent Handlebar,new exhaust=-
Help Me Pick New Handlebars for My KLX250S?!?
https://www.kawasakiforums.com/forum...ad.php?t=30076
DRILL NEW HANDLEBARS?
https://www.kawasakiforums.com/forum...d=1#post420771
Handle bars available
MSR
http://www.bikebandit.com/msr-profil...rs?m=17954&t=1
TUSK--Tusk is Rocky Mountain ATV's house brand.
http://www.rockymountainatvmc.com/pr...FamilyId=12330
Pro-Taper
http://www.amazon.com/Pro-Taper-EVO-.../dp/B001DOPN3G
Pro-Taper KX High bars
Pro Taper Twin Wall bars
Moose bark busters
Moose Competition
Renthal
Renthal 809 RC High bend
Renthal "Jimmy Button" enduro
Renthal 7/8 Carmichael bend bars
Renthal Twinwall-$109.95-->http://www.btosports.com/p/RTTWWL
Renthal Dimensions
http://www.dirtwarehouse.com/renthal..._motocross.htm
Handle Bar Specs
http://www.rockymountainatvmc.com/handlebarinfo.do
Pro_Taper Installed Pic From mudjunkie
http://i136.photobucket.com/albums/q...e/IMG_0970.jpg
Stock From mudjunkie
http://i136.photobucket.com/albums/q...e/IMG_0967.jpg
From mudjunkie--Stock Bar Measurements--2006 KLX250S
Here's what I measured on the stock bars (to the best I could with measuring tape and a level)
width (tip to tip) was 785mm
height (from bottom of bar at clamp to bottom of bar at outside end of grip--vertical height) was 50mm
rise (length of slope between clamp area and where bend starts for grip area) was 35mm
clamp area (length of straight bar in clamp area) was 150mm (clamps are 110 outside to outside)
sweep (the amount of bend in the grips towards the rear of the bike) was 90mm
I don't know how accurate this was, but I used this info when sourcing out an appropriate bar for what I wanted to achieve.
Updated as of May 22-2010
MSR handlebars
handlebars
why new bars?
MSR
Pro-Taper
Moose bark busters
Moose Competition
Renthal
Renthal Dimensions
Handle Bar Specs
Now my question is what is the best or strongest handlebar? I want something that can take a beating.
-I read that tusk is $27.99, but some people have bent theirs and are on their second set.
-Moose is sometimes hard to install.
--Pro-Taper is excellent quality and can take many beatings without bending.
DOES ANYONE AGREE WITH THIS?
I had a bad fall 2 days ago that completely bent my handlebars, broke my left mirror, and i sprained my foot really bad.
I just replaced my bars for the second time with a set of jimmy button renthal bars, they sit an inch or so higher which is welcome. The local shop claims pro-taper will replace any of the fat bar range free of charge if you bend them...so if you want a garuantee i would go for them.
I looped my bike over myself and it fell on the handlebars from about 10 foot(near vertical climb and the bike slowed and fell backward past the balance point) then onto me, and it bent my old RDX bars (look indentical to renthal) about an inch down and 2 inches back...I am hoping a geniune renthal bar will be stronger..but also hoping i dont try to catch my bike with my nuts from a 10 foot drop again.
replacing a set of bars takes about 15 minutes, i take about half an hour because i have barkbuster gaurds.
Nice research here and well timed. I just placed an order for Tusk CR Mid bend, D-flex handguards, grip heater kit, and pro-taper pillow top grips.
I just bought Pro-Tapers CR-Hi SE bars with Moose contour Bark busters. Also bought some nice bar-risers from Pit-Posse that come with spacers and different length bolts so the height can be adjusted.
Twinwalls were the best move for me - I bent a few sets of bars before getting the Twinwalls, and haven't needed any other bars since. And that is in spite of a few big crashes that I expected would bend the bars!
I used the Tusk Universal Big Bar Clamp Kit from Rocky Mountain ATV for $35: Tusk Universal Big Bar Clamp Kit | Rocky Mountain ATV/MC
