nail is sf tire
When you're talking about tires for motard type street use, you're going to see some good tubeless tires that work for that application. You can still run them with a tube. Now, there is some debate about some of the really big road burners, like Goldwings and such, as to whether it's the best deal to put a tube in those tubeless tires. Some of these bikes are big, heavy, and do some high speeds. That can generate heat, and a tube within a tubeless tire carcass might generate more heat. Personally I don't know. It's an argument that's out there. I run Nuetech Tulbiss on my KLX250S. They have been totally reliable for 3 years now. Unfortunately Nuetech doesn't have a 17" application at this time, or that's what I'd run if I had an SF.
IE a Z rated tire should be used as a W rated tire when running tubes.
