My bear encounter
You would never have got the gun out. You probably have more chance of hurting yourself with the gun than getting hurt by a bear. There are so many humans around it stands to reason the odd one is going to become pray. I have worked climbed hiked in the bush my whole life, come across many bear cougar and never once been threatend.
they will always run if given the option unless in your case something is amiss, and as I said you would have had to been a pretty quick draw to get the gat out.
True dat.
One thing nobody mentioned was that if a black bear does attack, very unlikely but does happen, the fight is ON!!!. You never play dead with a black bear, full on fight for your very survival. That bastige will eat part of you if he attacks. Grizz you play dead and/or look down ..... that's a dominance thing.
Did you happen to get a release form? Haha just messin.
That's a great story to tell now.
-Nick
Your lucky, it could have been much worse. I'm sure you have a few more gray hairs and unclogged a few arteries after that encounter!
I came across a black bear riding a couple of weeks ago (he was down a side trail as I passed). I didn't even want to take the risk and stop for a closer look. I've seen how fast they can run and could just see myself stalling the engine in a frantic effort to outrun or hitting neutral between first or second.
I would like to pack heat, but I don't know how much it would help in a situation like that.
Wow, good story.
Only thing I have to worry about is crazy Kangaroos.
They panic and hop all about trying to get away.
And sometimes they hop right in front of you.
Same with Emus.
They just get frightened and run around like chickens with their heads cut off.
Why do people think the answer is to shoot the bear?
You are in his yard, not the other way around.
Same with Emus.
If he had enough time to put his camera away and turn the bike around he would have enough time to draw 10 pistols, let alone one.
If your riding in the wilderness with dangerous animals its always best to carry a gun. Go pick up a larger caliber handgun with some high velocity hollow points and set sail. Either that or bear pepper spray...and or a taser brand taser, because sometimes shooting charging bears (even through the heart) doesn't stop them, but pepper spray and tazers do....go figure. They can stop a bull dead still because they override the muscles. Only problem with those weapons is you gotta be REAL close. I prefer the safety of a firearm.
________
Cumshot belly
________
Cumshot belly
[quote
You are in his yard, not the other way around.[/quote]
Because its bear season, and I have a tag. But on any other occasion, I wouldn't just shoot an animal because they were there, only if I felt threatened and couldn't remove myself in a timely manner. DOH!! Speaking of tags, deer season starts on Saturday, and I need to pick up a tag for that. Hmmmm bear, cougar, deer, elk, grouse......oh my.
