MUFFLER vs HOLESAW
MUFFLER vs HOLESAW
Anyone here know the diameter of the hole that I need to make in the stock 06 muffler that would be a little undersize so I could then finish it with a dremel. I want to sort of mimmic Wildcard's patented klacker pipe mod. I just don't want to end up on the other side of the baffle tube in his pic on my 1st attempt.
-Steve
-Steve
Start close to the pipe with a small drill bit, then insert a probe to get an idea of the diameter, it should be close to the same as the the front of the pipe.
I would make a series of small holes around the pipe, then cut/pry it out, then fold any excess in to clean it up.
editised:
for Mike- open klx250s- select "search this forum" enter "wildcard endcap" select "worth it to modify stock exhaust" scroll 4 down and click.
For me- thanks, if I don't get answer for hole size I'll buzz around it like you say and start going in small. The strawl is attached only to the metal that I will cut and remove correct??
Thanks.....Steve
Thanks.....Steve
editised:
Thanks.....Steve
Thanks.....Steve
https://www.kawasakiforums.com/forum...inished-35018/
Mike
Best pic i got.....
Search for Marcelino mods or threads in the sicky posts and elsewhere. He covered the holesaw mod.
