Mr. 2009 has left the building???
RE: Mr. 2009 has left the building???
Actually the dealer that I got my bike from has it listed as 34.8 I know that's almost the same, but I wonder if the motor is closer to the ground, but they bumped the suspension up to compensate. Not sure on that one. Yea it does sound a little strange.
2009 KLX Specs
This is all from the same spec sheet that all the dealers use. I think its some sort of template from Kawasaki.
2006 specs
Specifications:
Engine Type: 4-Stroke, Liquid-Cooled, DOHC, 4-Valve Single
Displacement: 249 cc
Bore & Stroke: 72.0 x 61.2 mm
Compression Ratio: 11.0:1
Carburetor: Keihin CVK34
Ignition: Digital CDI
Transmission: 6-Speed
Rake/Trail: 26.5°/4.2 in.
Front Wheel Travel: 11.2 in.
Rear Wheel Travel: 11.0 in.
Front Tire Size: 80/100-21
Rear Tire Size: 100/100-18
Front Suspension: 43mm Inverted Cartridge Fork with 16-Way Compression Damping Adjustment
Rear Suspension: Uni-Trak with Adjustable Preload, 16-Way Compression and Rebound Damping Adjustment
Wheelbase: 56.5 in.
Front Brake Type: Disc
Rear Brake Type: Disc
Fuel Tank Capacity: 1.9 gal.
Ground Clearance: 11.6 in.
Seat Height: 34.8 in.
Dry Weight: 262 lb.
Color: Lime Green
2009 KLX Specs
2006 specs
Specifications:
Wheelbase: 56.5 in.
Dry Weight: 262 lb.
Color: Lime Green
ORIGINAL: deej
Hmmmm they are listing the 06 and the 09 as exactly the same weight. I wish Kawi would get their act together.
we're talking 15lbs. here though and the tires aren't any larger than prior years. I'm just wondering if someone earlier hit it on the head with maybe an underquoted or inaccurateweight on the old bikes.
That new rear swingarm must be really heavy...
I wonder if the new evaporative emmissions system that makes the bike California legal is on every bike? How much does that weigh?
I check the specs on the Kawasaki page vs. the specs on my dealers website. It appears that the template on the dealers website has not been updated...
Click on the 2009 specs I posted above. Dry weight 262, but really weight is all relative, I mean I've taken a dump and lost that much.[8D]
Yea it sounds like there are as many different answers out there as there are bikes. Oh well. Who cares about what a bike weighs. The KLX could have weighed 300 and I still would have bought it. Oh and as some of you know I also would have paid $10,000 for it, but that's just me and the way I feel about the bike. Its all good.
ORIGINAL: deej
ORIGINAL: 09KLXowner
dude..............................[:-]
ORIGINAL: deej
