MotorKote
#31
KLX678, I think it is a function of the reduced friction in the motor. The Motorkote is an additive to the oil that you do once every four oil changes. I used to have to add Seafoam to my gas all the time to eliminate the hard cold starting, especially after the bike sat for even just a few days. But since the Motorkote, no longer. I've had the bike sit for weeks without starting it and it fires on the first try. Honestly, I've changed nothing else.
#32
Motorkote
Motorkote works well in my 93 FLHS Harley. I use 6 oz in oil, and 1 oz in trans. I can tell the difference, especially in transmission. Old harley tour bikes are not built for speed, but motorkote gives me a noticable boost in power. Good s#%&t. Best Ive ever seen. I highly recommend it
#33
I do believe products like this work well, what i dont believe is that they soak into metal. Think about it, there is no way it can soak into metal. I use a product called Ar9100 for diesels. This stuff really makes a noisy diesel much quieter, which tells me it is coating all the internal parts with a tough film motor oil doesn't do, extending the life of everything. I now put in in all my bikes and diesels. But it is pricey.
https://www.archoil.com/products/ar9100-oil-additive
