MOOSE 13-tooth front sprocket
Old 08-27-2006, 08:51 PM
Waxface's Avatar
Default RE: MOOSE 13-tooth front sprocket
there in stock again at dennis kirk ,,,just ordered mine
  #32
Old 08-28-2006, 12:33 AM
YYY.GUY's Avatar
I just posted a new part number under the Part Numbers thread (call me silly) for a Kimpex 13 tooth sprocket:
Kimpex #101006
It fits without needing a spacer/shim, and doesn't seem to increase noise.
My biggest problem was getting a sprocket in Canada. The Kimpex part is what my local dealer (Ottawa Goodtime Center) tracked down for me. Had it in 3 days and at a great price ($12 Cdn ... must be on clearance or something from the supplier.)
I agree that a larger sprocket in the back is a better long term configuration, so I'm planning to swap back to the stock 14 tooth sprocket when the OEM chain needs to be replaced.
Mike
  #33
Old 08-28-2006, 09:04 AM
Bulls90's Avatar
Moose Racing confirmed their 13t socket is not the right fit for the KLX250S. The said they would inform Dennis Kirk. I haven't seen them take the product off their "fit list." Anyway, you can fabricate a spacer to fit between the sprocket and the crank case or you can order three (3) washers that are used to lock nut to the counter shaft. That's about the same tolerance needed. I think bike bandit sells them for about $3.50 per washer.
  #34
Old 08-28-2006, 09:06 AM
I traded a dozen donuts to a friend of mine that owns a machine shop and he made me a 105 thousandths spacer.
  #35
Old 08-29-2006, 05:13 AM
Grateful_Rider's Avatar
Hi Guys
I just got the counter sprocket for my klx250s. I got it from PBI sprockets. It was 23 and change. That is cost and shipping. It is the correct one, the splines and collar matches the factory sprocket. The part number is 453-13 C/S. It took him 2 days to get it to me.
  #37
Old 08-30-2006, 12:37 AM
Waxface's Avatar
has anyone spoke to dennis kirk? why would he continue sell the wrong part?
JasonFMX
09-28-2008 03:11 AM
07 KLXER
06-12-2008 12:14 AM
mugwump
Ninja 500R
02-14-2007 03:25 AM
yzkiley
10-19-2006 03:57 AM
Quick Reply: MOOSE 13-tooth front sprocket
