Monitoring fuel/air mixture - O2 Sensor?
RE: Monitoring fuel/air mixture - O2 Sensor?
ORIGINAL: Ziguy
Nobrakes, Do you any schematics for your setup? Do you just filter the sensor output? Do you get steady results?
I decided to go with the K&N kit that I referenced above. Finally got my Muzzy and drilled the hole. I'm having the fitting welded on tomorrow.
I'm going to try and dial in the stock carb while I'm waiting on the Mikuni TM33(34) from Bill Blue.
Dan,your info on the stock carb will be very helpful for those of us that are currently stuck with the stock carb. [:@] Unless I am forgetting something, I don'tthink anyonehas used an O2 sensor with the stock carb yet. What elevation are you at? I see you are in Colorado, so I am figuring you are quite a bit higher than many of us. Either way, it will be good to have some real data as a line in the sand from which to extrapolate for our own elevations.
Thanks for taking the time to do this on your stocker.
Northern Tool Company has the perfect tool for fuel/air mixture specially on these 1 cylinder bikes. It's called a color tune combustion tester. It is a spark plug with a window in the top to see the color of combustion . Different combustion temperatures are different colors so a chart that tells you what color means rich, lean, right on etc... The tool runs 60 bucks and works very well. Hope this helps ya
Installed the K&N Air Fuel Ratio Monitor kit and spent the past few days playing with the carb settings. I've become pretty fast at getting the carb on and off (even faster than the carb rack on the ZL900 eliminator that I had for 18 years). I believe that Ihave my bike's carb tuned pretty well now.
Here's my setup/environment:
Modded stock carb CVK34
- 7/64" slide drill
- N1TC jet needle - 1st clip
- Kouba fuel mixture screw - 1 - 1/2 turns out
- Keihin 128 main jet
- (replaced float bowl and vacuum valve cap screws with socket head cap screws)
Smog stuff removed and capped
Crankcase breather mod - capped airbox hole and ran a 19/32" PCV hose up to the top of the airbox with a K&N crankcase breather filter
Backfire screen removed
Airbox lid off
K&N Air filter
Muzzy full exhaust system with quiet core and spark arrestor screen installed
Altitude: 5000'
According to the monitor (tests done under load):
- idle set to ~1350 RPM and the mixture is spot on
- up to 1/4 throttle good but goes a little rich
- 1/4->1/2 rich
- 1/2 -> 3/4 rich to good
- 3/4 -> WOT - good
I'm a bit rich in the low midrange. I started out with the clip on the 2nd notch and I was really rich with a lot of popping on deacceleration.
Moved it to the 1st notch and things got better with only some occasional popping. I'm considering putting the stock needle back in and
adjusting it with some washers.
As for the feel of things, pulls real good up to about 8000RPM, a little stutter there but I usually shift before then anyway. Under load and WOT, pulls hards all the way.
The O2 sensor and monitor is a temporary install for tuning. I'll use it a couple more times for tuning the TM33/4 and 330cc kit.
I traded off "destroying" the headpipe against taking a scientific approach to tuning. If the appearance of the fitting and cap gets to me,
I may get another headpipe (but I doubt it).
- 7/64" slide drill
Airbox lid off
K&N Air filter
Altitude: 5000'
- 1/4->1/2 rich
- 3/4 -> WOT - good
