Milky substance on oil sight glass
Cool sounds good. So TNC without getting everyone fired up over the oil issue, you think it is fine to stick with the regular oil? The only reason I was gonna switch was because I was told the synthetic gave better protection over the parts and dosen't burn up as fast(or loose its quality as fast). What you think?
Assuming there is no coolant getting into the oil, another source of 'milky substance' can be blow-by condensation which occurs every time you fire a cold engine. Once it gets up to operating temperature, this condensation normally evaporates but if you are only running short errands or commuting, the condensation doesn't get a chance to boil off resulting in the white cream you see in the oil.
Try to always run the engine up to operating temperature once it's been started...
