mikuni tm36-68 owners help
Old 10-06-2011 | 12:40 AM
T_i_G_e_R's Avatar
Default mikuni tm36-68 owners help
I know you are out there.
I have the top 3/4 throttle perfect, but I dislike the sputtering from 0- 1/8 throttle (not too rich type of sputtering from 0-1/8 throttle, but lean type) Ive tried everything.. the only way it goes away is if I make everything too rich by adding a rich needle or rich needle jet. I have it ALMOST perfect now, but there is just one tiny blip about 1/8 throttle.. it drives me nuts.. Ive tried every size pilot jet pilot air jet combo, needle, needle jet, a/p position.. etc.
Old 10-06-2011 | 02:36 AM
RaceGass's Avatar
Your signature doesn't mention if your airbox lid is off, if so try blocking off different percentages of it with duct tape to see if the lean condition off idle to 1/8 throttle can be eliminated.....
Old 10-06-2011 | 04:05 AM
T_i_G_e_R's Avatar
it not off.. kdx snorkel.
Old 10-06-2011 | 04:08 AM
T_i_G_e_R's Avatar
I changed to the stock needle, p4 needle jet, 22.5 pilot jet, and it seems better now. Does cold weather make things run leaner?
Old 10-06-2011 | 05:48 AM
Brewster's Avatar
Have you adjusted the start of the a/p and the duration?
Ride on
Brewster
Old 10-06-2011 | 12:02 PM
linkin5's Avatar
The colder it is it does go leaner but not usually enough to require a jetting change.
Old 10-06-2011 | 08:24 PM
T_i_G_e_R's Avatar
i tried that brewster and it fixes it when you are twisting only.. if you keep the throttle 1/8 open and leave it there.. bike jerks and sputters.. too lean or very turbulent something or other ..
does adding race cams cause leaner condition?.. i would think so.. more air flow
Old 10-07-2011 | 12:25 AM
David R's Avatar
I was close to how yours is jetted. I used a P6 needle jet which cured the low speed sputter. Raise your needle one notch may help too.
David
mustang
09-20-2013 08:11 PM
bailor
05-04-2009 05:59 PM
boxermachine
03-24-2009 10:12 PM
ericccarbonneau
03-02-2009 11:48 PM
bailor
02-28-2009 01:08 PM
Quick Reply: mikuni tm36-68 owners help
