Mikuni TM33
Old 04-10-2011 | 01:39 AM
duder's Avatar
Default Mikuni TM33
Anybody ever switch out the stock carb for the Mikuni TM33? I bought a new one for for my 94' dr350s from carb warehouse and am thinking about trying it on my 2009 klx250
Old 04-10-2011 | 04:11 AM
It's been done. Try a search here on KF , plenty of info if you plug "TM33" into the search box.
Old 04-10-2011 | 09:49 AM
neilapples's Avatar
TM36 fits way better than the TM33.
Old 04-10-2011 | 02:50 PM
Feral Donkey's Avatar
There's 2 routes you can go with the TM33. You can buy one from Bill Blue that's been bored oversize and fit with adapters front and back, and the throttle cable bracket has been chopped and rewelded, or you can do it all yourself. It's a pain in the butt to get the cable bracket right and you can only use your pull cable. The adapters have to be made in a lathe. And it can be fit without having to grind clearance on your frame, but it's hard to do. Things get tight in there.
Now these guys on here have discovered that a TM36 pops right in like it was meant to be there and you can use both cables. If I had to do it over again, I'd do the TM36. Seriously less screwing around.
vfrpilot
11-13-2010 01:13 PM
DJFields
05-17-2007 02:25 PM
johnnyz62
03-15-2007 06:47 AM
toomuchdust
01-22-2007 02:59 PM
bryanklx250s
01-20-2006 01:15 AM
Quick Reply: Mikuni TM33
