megabomb header melting airbox issue
I agree. Loosen all the bolts on the system, wiggle it around to get the best fitment/clearance and start to tighten at the front and work your way back. I have no melting, but did find I needed to add a washer at the front muffler mount as it did not sit flush when test fit. If I had not done that it may have pulled in too close to the airbox? FMF does seem to have alot of fitment issues on various bikes.
I think the airbox on the efi bike is slightly bigger or lower than the US carb model from what i've seen in pictures on here.
I wasn't feeling the lowering brackets when my mechanic suggested them, I figured it would be a temp measure but that was 10 months ago & there still rock solid & looking pretty permanent now.
Not much else you can do to get the needed clearance. Lowering brackets seems like a decent solution. The Powerbomb header doesnt have the same issues when running a two bros canister.
did a really long ride on freeways at 80+ mph...and some twisty mountains...heatshield prevented pants from melting...airbox okay...but, temp were 60s today...not a great test ride
What sort of heat shield are you using?
hmm...installed the megabomb today and i don't see the header pipe even coming close...the slip-on pipe connects and that pipe only one the appears close to the airbox...unless the heat from the megabomb is increasing the overall temp of the exhaust pipe and muffler....hmmm....i'll keep a close eye on mine...i may just wrap the the entire header and muffler pipe....can't believe my pants started melting so quickly...not sure if the heatshield is going to be enough...
updating both megabomb threads..haha...but, yes...the fmf heatshield is working fine for now...i don't think i have any hot weather coming up to test it in hot weather...sf tends to be cooler...
Klxster
05-30-2014 06:08 AM
