MEGABOMB DYNO TEST-before and after
Old 04-04-2014 | 03:41 AM
wildcard's Avatar
I think it was also tested by other members that the aftermarket carbs (tm34 or tm36-68) don't improve power only throttle response
at least one dyno seems to indicate otherwise -
https://www.kawasakiforums.com/forum...lx351sf-29316/
Post #38 has the best scans of the dyno charts.
Old 04-04-2014 | 03:58 AM
RockabillSlapMatt's Avatar
Whoa! I stand corrected! I wonder what it would be like if he put the stock header back on with all other modifications still present.
Old 04-04-2014 | 03:35 PM
ahnh666's Avatar
this this
will give you 10 hp...
Old 04-04-2014 | 06:38 PM
zippets's Avatar
that will tell the truth
Old 04-04-2014 | 11:15 PM
Frampton's Avatar
did the megabomb atleast reduce sound like they say it will do?
Old 04-06-2014 | 03:46 AM
Klxster's Avatar
Sorry to have been absent .. I'm back at work, in the oil field, and just now able to log on..
Each was a 3 pull dyno run. Run 002 was the best of the 3 pulls with stock header. Run 005 was the best of the megabomb pulls.
In deference to Richard Avatar, the side plate was left off the bike for all pulls. There is a difference. It did lean out the bike. Run 002 is much leaner than my pulls after installing the #132 jet a number of months ago. I have no way to easily richen the bike except by raising the needle.
Showing the AFR should provide many with the info they need for jetting. See the proof in the chart - near sea level, putting in the biggest DynoJet main is not enough if your bike is modded like mine and you further enhance the airbox . Best power production occurs at 12.8 to 13.0 AFR.
Old 04-06-2014 | 05:30 AM
Richard Avatar's Avatar
Interesting that the side cover off would change a/f ratio even though there's no holes in your air box. There must be quite a restriction with everything all buttoned up?
The plot thickens
With a CV carb dependent on vacuum to bring the slide up, it'd be hard to say where the line is between too little/too much vacuum effect
  #28
Old 04-06-2014 | 05:37 AM
I was thinking this last night in reference to the dynos linked by wildcard
You can't say for certain the larger diameter, or even a pumper carb gets better hp without comparing like fuel ratios. If the cv carb is running rich or lean, and the pumper is spot on, then of course the pumper will make more power. Vise-versa is of course true.
So unless there are dyno AFR's proving, with spot on (or at least similar) jetting between carbs, showing the aftermarket is better, we truly will never know.
It seems nit picky, but when dealing with usually less than or equal to 1hp increases it seems that even the smallest occurrences changes the outcome drastically To eek out more power it takes a fine tooth comb for sure
  #29
Old 04-06-2014 | 10:28 AM
Klxster's Avatar
I suppose I should raise the needle one slot and modify my slip-on to match up with the I.D. of the megabomb. Perhaps without flow restrictions through the slip-on's nipple and a little richer AFR, the megabomb will make a better showing.
I cannot tell any difference in the sound of the bike. Its' still loud - thank goodness!
Klxster
01-26-2015 01:42 AM
Klxster
03-06-2014 05:16 AM
deej
08-13-2006 08:44 AM
Bonafide
06-09-2006 01:45 PM
Quick Reply: MEGABOMB DYNO TEST-before and after
