Maxxis M6006..........check
Old 01-12-2007 | 11:22 PM
jeepphamilee's Avatar
Default Maxxis M6006..........check
Well I am onspending spree for my bike, figured while I am blowing money it was time to replace my tired Dunlop603's they are now slicks. After a lot of reading and research and inputs from the great forum and broke down and bought aset of Maxxis M6006's
I got the closest thing to stock sizes front is 90/90 21 and 120/80 18. $38 each at bike bandit. I will be curious to see how long they last but at $38 each they are pretty cheap and if I get 2500-3000 miles out of them even better.
Oh, I installed my 45T and 520/108 chain last night and rode around a bit. Much snappier and stays in the good rpm range as you shift. Lost a bit of top end on the highway but I think it was worth it so far. I knew there was talk about not knowing of the 108 link would be the correct size, it is and I have mine set at the 3rd click on the ajusters. So there is plenty of adjustment left for stretch and crap.
Old 01-13-2007 | 01:03 AM
motoguy128's Avatar
Default RE: Maxxis M6006..........check
Those should be a little wider than stock. I'm curious how they fit and ride. I'd like something a little wider. I ride often with my fiancee on the back and a wider tire would be a little more stable on gravel roads. It should wear a little slower since the wider tire disperses heat better and there's less force per area on the contact patch. Turning should be a little slower, but that's not a problem with the wide bars.
Old 01-13-2007 | 08:24 AM
KAWASAKIspeed's Avatar
I do not know but this is just ehat i have heard that those tires do not do well in the water. i do not know. so good luck with the spending spree.
Old 01-13-2007 | 08:54 AM
I don't plan on going swimming with them Everything does crappy in west Texas when it rains, it's like a freaking ice-skating rink.
11-27-2011 02:01 AM
WestOzKLX
03-20-2010 10:11 PM
kgwld1
12-12-2008 12:37 AM
jeepphamilee
02-05-2007 04:53 PM
ZX12Rider
02-03-2005 03:54 PM
Quick Reply: Maxxis M6006..........check
