Making TM36-68 richer
My stock KLX250S will make the header orange at night when riding slow through the woods in 1st and second gear revving it up on the trails.
It is 100% stock. Snorkel in place, stock exhaust, and stock jetting.
Thanks! Makes me feel better that I'm not a one off.... how aBout idling for say 5 mins?
Almost all single wall exhausts will glow red even orange if left sitting and idling for several minutes. Exhaust gasses are around 1300-1500 degrees, more than enough to get a good glow going. It only takes about 900° for steel to start to glow red. The cool air when riding will cool it below a glow.
I had a well jetted SR500 single glowing bright red in sub-freezing weather when I let it idle for about 8 minutes or so to warm up. Within less than a quarter block it was no longer glowing.
It isn't unusual and it is not a sign that the bike is running too hot. That is found with spark plug readings in absence of any sort of instrumentation for more accurate readings. Temperatures at the exhaust valve can be between 1200-1800°F. Plenty warm enough to create a glow on a steel pipe without any air circulation around it.
What about ceramic coatings? Do they help?
Different animal but my friends yfz450 atv would make the header glow noticeably during the day. That thing would get so friggin hot I thought my legs were going to catch on fire! We had it out one night drag racing against a friends 2014 RMZ250 and I was running the crap out of it. It shut down, I had no idea why I looked down and the header was glowing like crazy. Turns out it was out of gas, and I just didn't pay attention. But man what a scary sight.
Boooooo! I'm holding out for a little more dirt before sleep time
Ceramic coating keeps the heat in the pipe and the ceramic will not glow. I have ceramic coating on the KLX650 pipe. It doesn't radiate heat as much - thus it is keeping it in the pipe. Heat keeps the velocity up on the exhaust gasses and that is good for performance, extracting exhaust from the cylinder better - learned that from muscle car and racing stuff I've read over the years.
Really nice part about ceramic coating - no maintenance. It may get a bit dull from the heat on the head pipe, but no rust or corrosion.
So...... The more I delve into the wonderful world of carburetors, the less **** makes sense lol...
If I understand correctly, and quite possibly I'm out to lunch and fully expecting to get called on it, one jet will not necessarily richen a carb, I'd need to swap out all the jets, as they all act on different areas of operation...but some say swap 1 jet at a time... Pain in the *** to remove/reinstall the carb multiple times tho.
Now, apparently, I can introduce less air (lid on, snorkel off) by covering part of the intake, but that seems kinda sketchy. How much do I cover without really screwing stuff up?
Anyways, still banging away at this slowly.... Almost time to put her to sleep for the winter, so kinda taking my time.....
Yup, my thoughts exactly, just trying to see if a richer mixture will result in cool runnings (lol, get it, the movie???)
