Lowering links question
Old 03-23-2012, 04:37 AM
ol guy's Avatar
Location: Kennewick Washington, in the washington desert
Sorry, i didn't think about the year. Mine is an 06.
Old 03-23-2012, 12:08 PM
Spyke's Avatar
Thanks everyone for all your help. I can see its about 5mm = 3/4" drop. I will make some up and give it a try.
Old 03-25-2012, 10:49 PM
EZman250's Avatar
Default Lowering Links
Had a chance to see and measure the following for a 2006
Stock 117 mm
#3 124 mm
#4 130 mm
Old 03-26-2012, 05:41 PM
Spyke's Avatar
Ok, got my dog bones made up. One at 125mm centers and the other 130mm centers. They are 2" wide stock, that's all they had. I will have to check for interferences. Im just going to used them to see what size I need and then I will order a set of aluminum ones. I will update how they work out when I get a chance to try them out.
Old 03-26-2012, 06:14 PM
ahnh666's Avatar
if you already made them with steel..might as well just use them....stronger than aluminum...
Old 03-26-2012, 08:15 PM
Spyke's Avatar
I might use them. I have to make sure they aren't too wide. And also I wouldn't want them to rust. So we will see.
Old 03-28-2012, 07:40 PM
drawjim's Avatar
I bought my 07 KLX last fall as a non-runner basket case. At 5'7" I could barely swing my leg over the thing, so knew some lowering was in order!
I rebuilt my lower suspension linkage utilizing some 119.5 links from a 2009 KLX I had picked up off ehay. I was hoping that 2.5mm longer link would drop it at least an inch, at least that is what I read on some other forum. It dropped it a bit, but not nearly enough. I am guessing less than 1/2". Not enough.
So I ordered a set of 1-1/2" lowering links today. About $29 total. Anxiously awaiting delivery. I spent all winter re-building this bad boy bare frame/motor to finish, have never even ridden it yet. Getting awul itchy!
Old 03-29-2012, 12:45 PM
Spyke's Avatar
Let me know how you make out. Thanks
Old 03-29-2012, 08:22 PM
zomby woof's Avatar
Mine are made of cold rolled mild steel. I used them unpainted for over a year, and they were fine until I went down a gravel road that had just been sprayed with calcium chloride. Everything on my bike started rusting after that.
I have found spray on bedliner to be quite good for applications like that.
Old 04-07-2012, 05:20 AM
Lotrat's Avatar
I just got my 1.5" lowing links for my 2009 KLX250S.
119.5mm = Stock
131mm = -1.5"
I'll measure the bike before and after to confirm.
Quick Reply: Lowering links question
