lowering links: Kouba or Ebay guy or?
Old 07-08-2008 | 10:47 PM
fireroad's Avatar
Default lowering links: Kouba or Ebay guy or?
Hey everyone, long time no post. After an 8 month hiatus I'm back on my KLX again. When last I left off the suspension was the next upgrade for me. First order is to lower it a hair, then replace front fork springs to my weight. My question is...did the arguement of whether it was better to spend the money for Kouba's 0.75" link or save the money and go ebay guy 1" link ever get solved? Money is always an option, but I'm more concerned about geometry and saftey. Is there another source for the links?
I guess that I should lay out my whole plan...lower, then upgrade the front springs to equal rear (I'm 200lbs), then upgrade to one of those really nice seats that nobrakes has (name?). Is this flawed logic?
Old 07-09-2008 | 01:13 AM
neanderthaler's Avatar
Default RE: lowering links: Kouba or Ebay guy or?
pm sent. one note. when you remove the nuts from the linkage, use a 6 pointed socket. i stripped mine out with a 12 point and had to replace 'em.
Old 07-09-2008 | 01:30 AM
lcpl0331's Avatar
that seat is a renazco(?) they're huge money though, $300 or thereabouts.
Old 07-09-2008 | 03:34 AM
ORIGINAL: lcpl0331
Yep, http://www.renazco.com .
I like mine. Makes those longer trail connections a bit more bearable, especially at the end of the day when you're riding home after a full day of hitting the dirt.
Old 07-09-2008 | 04:05 AM
neilaction's Avatar
If you go for lowering links, best to raise the forks in the triple clamps to keep the balance right.
Or the steering will be slower. (could be a benefit for extended road use i guess)
The most you will get is 1/2 - 3/4 of an inch.
Firming up the front springs and possibly increasing rear preload to balance may negate the effect of the links.
IMHO links are a bit of a copromise but work ok for what they are.
After much messing around I resolved the issue once and for all.
https://www.kawasakiforums.com/m_306554/tm.htm
Old 07-09-2008 | 08:09 PM
KLXer's Avatar
Id try to avoid the links if at all possible, even if it means running more sag than you should with the stock links, at least then it wont alter the rate of the rest of the shock travel.
Old 07-09-2008 | 08:50 PM
Bad Bear's Avatar
I have been using the Kouba links with no problems I set the sag and slid the forks up about 3/4 " I also used bar risers to help with my bad back.....
Old 07-11-2008 | 08:50 AM
MaverickAus's Avatar
https://www.kawasakiforums.com/m_119325/tm.htm
Old 07-12-2008 | 02:12 AM
I bought the raising links from the ebay guy no problems.....sped up the steering and helped the geometry...just sayin.
Old 07-15-2008 | 02:13 AM
fireroad's Avatar
neander my pm is broke email me at b_davis@excite.com
EZman250
09-01-2012 10:09 PM
eyedragaknee
02-23-2011 02:47 PM
TeamKLX250
03-11-2007 03:11 PM
klxstiffler
01-07-2007 01:55 PM
rkutzner
05-15-2006 07:53 PM
