Looking for a new trans
Old 09-10-2015 | 03:16 AM
RANGERRANDY90650's Avatar
Default Looking for a new trans
I'm looking for a new trans. Or basically a whole new engine and trans for a 2006 or newer
Old 09-10-2015 | 06:42 AM
surferdude's Avatar
Try Bike Bandit. They might have it there.
Old 09-10-2015 | 01:54 PM
vlodpg's Avatar
Keep checking here & also Ebay
Old 09-10-2015 | 06:23 PM
lj-rubi's Avatar
I have an engine/trans from an '09 bike that ran great when pulled from a wrecked bike recently. I can send you a link to YouTube video of the bike running before I disassembled it. Will drop you a PM as well.
Old 09-11-2015 | 11:23 AM
CousinLarry's Avatar
I have a trans from an 07 with the taller 6th gear.
Worked perfect. I pulled the motor because I popped a hole in the bottom of the crank case and got a new motor.
I am in CT. Send email if you're interested - everything AT cousinlarry DOT com
Old 09-11-2015 | 05:37 PM
griffo1962's Avatar
from his description in his other thread and as per KLX678 I think it's more likely to be the topend that has "seized". motor run without oil......... those ball bearings in the trans are pretty robust, not so the plain bearings in the head for the cams....... might get away with just a replacement head & cams but you won't know until the cam cover comes off............
Old 09-11-2015 | 05:40 PM
Werloc's Avatar
Uyless1
06-09-2019 04:25 PM
chromedome
02-23-2017 01:38 AM
AClark
03-30-2016 07:22 PM
CrazyeyesZx6
08-02-2006 02:01 AM
grafhky52
09-26-2005 05:57 PM
Quick Reply: Looking for a new trans
