Longer clutch cable
Part number 54011-0009 is for a KLX300R clutch cable & is 2" longer than stock. I had to buy one when I fitted a bigger handlebar with risers!
The throttle cables are pretty long & most big bars even with risers work ok (mine did), if your bars are really big then you can get got some extra length by re-routing them.
This handlebar simulator will give you a size comparison to look at. My bars are the fatbar (1 1/8 in (28.6mm) motard medium bend with 1.5inch riser clamps.....quite a bit higher & wider than stock setup & just required a 300R clutch cable. I could go an extra inch higher on the bars & still use the stock throttle cables IMO.
ZETA HANDLE BEND SIMULATOR
