Longer Cables?
Old 05-18-2011, 10:56 PM
flateric's Avatar
Default Longer Cables?
I know it has been discussed somewhere else in different threads but I was looking at putting together the reference numbers for each of the cables (and not different thread for different cables). Here is a list of the cables I think would need to be longer in order to fit a higher handlebar:
- Clutch
- Front break
- Throttle (x2?)
The electrical cables could probably be repositioned to get a few inches.
Could someone reply with reference numbers for each of the above cables (and I will do the same as I search the forum)?
Thanks
Old 05-18-2011, 11:11 PM
akarob's Avatar
Motion Pro will have no trouble making them for you. I just got my new throttle and clutch cables yesterday. As soon as I finish this, I'm going out to install them.
You need to call them for special orders. It'll cost you about $100.
Old 05-18-2011, 11:15 PM
flateric's Avatar
$100 per cable?
Is there a reference number I need to tell them in order to get the correct part? Or just tell them "09 KLX250SF 3 inches longer clutch cable" and they would know?
Old 05-18-2011, 11:40 PM
And is the '06 different from the '09? Time for new bars, and the clutch cable is about to break so now's the time.
Old 05-19-2011, 02:50 AM
akarob's Avatar
My 3" cables are just a touch too long. I'd go with +2"
And it's about $100 for the 3 cable assemblies. Comes with everything the stock cables have. There's no part number, they just know what you need.
Old 05-19-2011, 03:23 AM
ol'klx-er's Avatar
akarob, what had you changed, higher bar, risers?
Old 05-19-2011, 04:34 AM
flateric's Avatar
I think i will order them very soon then...
Thanks.
Old 05-19-2011, 10:33 AM
akarob's Avatar
Yes, I put on a 1 1/8 Renthal bar with small riser-adapters. I'll start a thread pretty soon describing my upgrades and my experience installing them. I really haven't had one thing go right yet. *sigh* It's getting worked out though.
Old 05-23-2011, 10:35 PM
flateric's Avatar
Ordered it today... Just called Motion Pro at 650.594.9600 and told them I need 3 Inches longer cables for a 2009 KLX250SF and he knew what to order.
The prices are:
- Throttle Push -> 35
- Throttle Pull -> 35
- Clutch -> 40
Total of $110 + shipping (dont know yet but should not be crazy within the US).
Old 05-23-2011, 10:58 PM
akarob's Avatar
Here's a picture of my setup. I wouldn't call the job "easy", but installing the cables wasn't that bad. They're just routed in a weird way.
Quick Reply: Longer Cables?
