Little help with a parts list for my new 250
Old 03-06-2007 | 08:11 AM
Snal's Avatar
Default Little help with a parts list for my new 250
Finally got my cash together, so I hope to be picking up my NEW (leftover) 2006 250 tomorrow. I'd like to go ahead and get some sprockets, chain, an exhaust system (if they stock them), jets, needle, air filter, and anything else that I might need mod-wise while I'm at the dealer. I plan to do the break-in while it's stock...then go for the mods. Not really looking to go with a larger bore or anything like that right off the bat...just want to make her breath better.
For gearing and jetting, I'm at 2700' elevation and will ride in areas 2000' higher and lower with a rough ratio of 30% street and 70% trail (mtns). My street riding will likely be to and from offroad riding areas with a max speed of 60mph and a maximum street distance of 40 miles or so, so I'm more concerned with offroad gearing.
Any help would be greatly appreciated!
Old 03-06-2007 | 08:44 AM
EvildoerZX10R's Avatar
Default RE: Little help with a parts list for my new 250
Hey snal, glad to see you getting your bike! We will have to talk speed sometime. I would love to run a bike at Bonneville!
I would go with the 13t 45t then you could switch the stock 14 back and forth if you don't like that much low end. You will need a new chain. I ended up just getting a long 120 link chain and cutting it off. The bike has a master link so it's a snap changing out the chain. I am coming form street bikes also and didn't know they still put removable master links on bikes anymore. Exhaust is a heated question around here. There are basically 4 options I know of. HMF (slip on), Two Brothers (slip on), Big Gun full system, and the Muzzy full system. I have the HMF and it isa very well built pipe but needs a little help with the fit. (1/2" spacer will do it) I love the way my pipe sounds and looks but I am not going to comment on the other pipes because I don't want to start another "pipe battle" as for the jetting I will leave that to some of the other guys here. I just got my parts in for the carb and not sure which I will be using.
Old 03-06-2007 | 08:56 AM
Snal's Avatar
Thanks! We have team members inMcdonaugh(SP) Ga....and Blackshear...you should ride up and join us....check the ecta-lsr.com site for the schedule....I assure you that you'll never forget it!...lotsa really good folks!
I've been following the HMF thread, sounds good, and I have a metal fab shop, so I can make any kindof bracket.
Old 03-06-2007 | 09:11 AM
Wow, my parents live in Mcdonough. I'll look it up. I'll post some pics of the bracket I built for the HMF and I am sure you could improve on it if you go in that direction. I like the way mine turned out because it is 2" in closer to the bike. It doesn't stick out the back as much.
Old 03-06-2007 | 11:53 PM
JB1's Avatar
JB1
ORIGINAL: Snal
Im not telling you to buy these parts, read the mods and jets thread to see where you relate to altitude with others and pick and choose. https://www.kawasakiforums.com/m_67995/tm.htm
16009-1912--------Needle-Jet,N1TC
92143-1667--------Needle Collar (required for N1TC needle)
92037-1401--------Clamp, Needle Jet (Clip, required for N1TC needle)
92063-1069--------#125 Main Jet
92063-1074--------#128 Main Jet
92064-1108--------#40 Pilot Jet
KFS-3--------------Koubalink adjustable air/fuel t-handle screw
14073-1577--------Duct, Inlet (KDX200 Snorkel)
NU-2364ST--------UNI air filter
UP-104-------------UNI 5/8"ID Clamp-on filter (for the nobrakes crankcasebreather)
UFM-400----------UNI filter oil and cleaner
R112B45----------Renthal 45T rear sprocket
PDX520108-------Primary Drive 520/108 chain (othersmfgs work toojust get 520/108)
Thats all I can think of for now. There will be various small things needed but they are just local auto-parts help center stuff (plugs, 5/8 union, 5/8"id hose, clamps etc) available anywhere and all that depends on what all changes you do.
Read this for step by step on jetting.
https://www.kawasakiforums.com/m_100000/tm.htm
Old 03-06-2007 | 11:58 PM
cwgoff's Avatar
Snal, normally I go with RonAyers for parts, but since you are in Asheville, you out to check out MR Cycles. They are located in Asheville and they appear to have comparable pricing to RonAyers. I have never ordered from them, but you might be able to order from them and pick stuff up to save shipping. Just a thought.
Here is their info from their site (www.mrcycles.com)
MR Cycles
774 Hendersonville Rd. Asheville NC 28803
Phone: (800)359-0567 / (828) 277-8600 Fax: (828) 277-1862
Old 03-07-2007 | 12:54 AM
Snal's Avatar
Thanks Chris...the dealer that I bought the bike from (she's home BTW!!!!!!!!) had virtually no parts. The 4.5 hour round trip was well worth the effort though....I got a new 06 for $3999.00 out the door...they didn't try to sell me anything else. I'd faxed my info to them at 9am this morning, and the bike was ready to load when I got there at noon. I was at the dealership all of 20 minutes! This was in Tennessee...so I'll have to pay the NC tax when I go for the tag tomorrow.
GTackett
03-07-2014 11:57 PM
1984ZX900
12-02-2007 08:02 PM
Al
08-14-2007 10:53 AM
phranticness
10-26-2006 09:24 PM
motoguy128
03-07-2006 06:19 AM
