Lighting the way
That depends upon the jacket liner, since they range from 90W (Gerbings or similar) to about 60-70W for the Aero Stitch Kanetsu, Warm-n-Safe Calientito and the likes. I think the Tour Master Synergy Jacket is also in the low consumption group and has great reviews/ reasonable price.
Anyway, the KLX will handle a low consumption Jacket along with heated grips, so long as you're not running the Jacket on high setting all of the time. If you used somthing like the synergy heated vest, you would have even less consumption. I've haven't heard of anybody needing the high setting with either the Synergy jacket or vest...they really put-out some serious heat. EXO2 Strorm Rider vest also puts out excellent heat with fairily low current draw but is a bit more pricey than the Tourmaster gear...like twice the price.
Dean thanks for the input on the wattage, I am going to try 2 55w bulbs to start out with. Then if I find the 100w bulb I was gonna try it just to see if it can pull it.
The dual cibies & light frame weighs about 4 1/2 lbs. The stock light & cover about 1 1/2. About a 3 lbs gain but the output is about double.
The dual hid BD weighs 10.5 lbs. The stock light about 1 lbs if that, so about a 9.5 gain. I wanna see when I poop myself. There are no tight woods nearby only wide open desert & dunes.
The fork guards have that Effex carbon fibre sheet sticker stuff on them. Cut em out of a 11 x 18 sheet. The wife didn't like the I robot white look to them.
