Let's talk chain lube
Alright as some of you know I recently cleaned my chain, took out a link and re-oiled it with something the shop sold me for my O-ring chain. Well I no longer have an O-ring chain, and I think this oil/conditioner sucks. ( I know some of you are saying, "Is deej actually posting a thread that has something to do with bikes?" I know I've been waaaaaaaay to wacky lately, and I'm working on it. Anywho, I was wondering what you guys have found that gives the chain good lubrication with out slinging it all over the place. I talked this morning to a guy that has a son that races motocross, and he said the lube that they use doesn't do what mine is doing. You should see my wheel and tire, its covered in oil now. I keep trying to wipe off the "excess" oil and am getting frustrated with it. Is there a good lube that stays on the chain. Please no wax recommendations. Any thoughts?
Guest
Posts: n/a
RE: Let's talk chain lube
dude- i almost told you this yesterday when you were showing pics of your bike after you rode it to work. i too like a clean bike and i hate chain lube all over the rear wheel. here's what i think is the holy grail in chain lubes- it's simply PJ1 chain lube. i use it and it immediately adheres to the chain and does not drip AT ALL. wipe your chain down good, go ride it to heat it up and then come home and spray the PJ1 on it (you probably don't even need to heat it up). it will seal it up and it will also be lubed. kind of like a dry, lubed up chain. anyway, that's what i use and i'm kind of a clean freak like you.
I use 90 weight gear oil. One tiny drop on each o-ring and one drop on the roller of each link is all it takes. If you oil too much it will sling off, but keep it to those single tiny drops and that should do it with no or at least minimal fling.
ORIGINAL: suprakawigrl
They make it for off road too (see pic)
Even when I put way to much on it doesn't seem to go everywhere, most of the excess drips onto the garage floor in the 1st few minutes.
ORIGINAL: Iowaguy
Ha ha I just noticed the two coffee cans in the back ground, now that funny.
Here is the picture from before.
And now after, a lot cleaner, the spray is a clear formula.
Ahhhhhhhhhh That's better.
