Leaky oil fill cap
Old 05-27-2018 | 07:18 PM
addictedtogum's Avatar
Default Leaky oil fill cap
i noticed after my ride today i had oil leaking out from the fill location on my '07 Klx250s. Do these caps typically go bad? is this normal?
Old 05-27-2018 | 07:35 PM
peabrain's Avatar
the cap has an oring that is easy replacable
Old 05-29-2018 | 11:46 AM
Can i use any o-ring or does it need to be rated for oil? Does Kawasaki have an OEM one?
Old 05-29-2018 | 12:53 PM
peabrain's Avatar
i think it is just a standard oil resistant o ring, i think any motorcycle or car shop have them
kawa part number
92055012
Old 05-29-2018 | 01:26 PM
18mm, but need to measure the cross section to get the right part. You could simply take it to a good hardware store and find a near match. Metric O-rings are hard to find, you probably could order one at Fastneal.
Old 05-30-2018 | 06:17 PM
RaceGass's Avatar
Kraken and auto zone sell a box of assorted o rings (they have the vacuum port caps for smog emissions parts removal too). I found one a little thicker in diameter that helped keep the seeping filler cap clean
tucaz#2
05-30-2018 04:12 PM
vlodpg
04-16-2008 06:50 PM
suwabara
09-05-2007 06:01 PM
50 Slider
04-23-2006 06:04 PM
petezzr
09-13-2005 04:52 AM
Quick Reply: Leaky oil fill cap
