Last question on 13t sprocket (I promise)
Old 07-10-2007 | 03:46 PM
DC4500's Avatar
Default RE: Last question on 13t sprocket (I promise)
I found that only the stock sprocket required an impact gun to remove the first time. I have swapped back and forth a few times using nothing but a 1/2 drive and socket to remove the countershaft nut.
Old 07-10-2007 | 05:00 PM
TypeSH's Avatar
What do you torque the countershaft nut to and did you use a new washer. Do you bend the washer on all ends like it was originally or on just one end?? Do you seperate the chain or just give it enough slack to swap?
Old 07-10-2007 | 05:13 PM
DC4500's Avatar
Idon't use a torque wrench. I just snug it up nice and tight without monstering in on. I do use a new keeper washer each time and bend it over on just one side (that's how mine was stock). I do pull the master link on the chain which is no big deal. You'll end up having to adjust the chain when moving from one size to the other.
Old 07-10-2007 | 07:00 PM
TypeSH's Avatar
Do you know the torque spec for the cs nut? I know the axle nut is 80 lbs/ft.
VT2007KLX250S
06-11-2015 04:05 PM
deej
07-23-2006 05:52 AM
a16tony
07-12-2006 02:45 AM
DRH
02-27-2006 08:46 AM
crash
02-16-2006 12:14 AM
