Last question on 13t sprocket (I promise)
Old 07-07-2007 | 04:29 PM
Davebert's Avatar
Default Last question on 13t sprocket (I promise)
Does the Sunstar 34213 13t front sprocket have the built-in raised area and work without a spacer?
Thanks,
db
Old 07-07-2007 | 04:41 PM
Thunderchild's Avatar
Default RE: Last question on 13t sprocket (I promise)
Yes and Yes. That's what I'm running with no problems.
Old 07-07-2007 | 05:53 PM
Davebert's Avatar
Thank you my friend. After reading about 500 messages on the topic I am ready to order.
db
Old 07-07-2007 | 10:50 PM
TypeSH's Avatar
Would it be pretty easy to swapback and forth between the 13 and 14depending on the kind of terrain?
Old 07-07-2007 | 11:17 PM
niven's Avatar
Banned
Not on the trail for sure, unless you carry an impact wrench and compressor. You will be happy with the 13 tooth unless your name is Malcolm Smith.
Old 07-07-2007 | 11:54 PM
TypeSH's Avatar
So with an impact, how long do you think it would take to switch between the two?
Old 07-08-2007 | 12:20 AM
MaverickAus's Avatar
2 minutes if you leave the sprocket cover off
Old 07-10-2007 | 05:05 AM
TypeSH's Avatar
So is it nessasary to take apart the chain to remove the gearas mentioned in this post?
http://www.advrider.com/forums/showthread.php?p=2506001
I tried for over an hourto get the nut off.I tried to flatten the washer as best I could and I used an impact and a big breaker bar but still no luck. Iguess I'm going to have to take it somewhere with a more powerful impact
Old 07-10-2007 | 06:19 AM
niven's Avatar
Banned
If you have to remove the countershaft sprocket on the road or the trail I'm thinking contract.
Old 07-10-2007 | 06:30 AM
niven's Avatar
Banned
Have you ever had a wheel off? I don't mean that as a joke 2
Kilometers can be life and death.Sorry 1.374 miles US . Learn the procedure,might save your life.
Quick Reply: Last question on 13t sprocket (I promise)
