KXF Cycra Front Fender mod install
I ordered a 2004-2008 KX KXF fender and here is how I made it work.
Drilled out the rivets on the speedometer cable guide and relocated it on the new fender using screws but will probably go back an rivet them in.
I put the stock metal bushings from the factory fender into the new KX fender. I used a thin washer on the rear to move the rear of the fender away from the frame. I was surprised it didn't need more shimming but it cleared.
The KX fender will press up on the bottom of the headlight assembly but it didn't seem to stress the plastic enough to worry about.
Shinny new fender
Shinny new fender
