Klx351sf
Michael, did you by any chance ask what they'd charge to do the conversion? I asked about it but it seems they are having trouble getting an answer from Bill since he's gone a lot.
Norm
Norm
I chose to do the work myself because, well, it's what I do for fun.
Michael
Thread resurrection! :-)
I believe this is the bike I purchased this afternoon from the original owner up in Sedro-Wooley. Said he bought the bike from Skagit Powersports with the 351kit, FMF Power bomb header/FMF muffler, pumper carb and pro taper handle bar on it from the dealer. The original invoice/paperwork I have shows a sale date of 8/27/09 with 504 miles on it. He also gave me the dyno sheet showing the different states of tune (stock/big bore kit only/bigbore and pipe/bigbore, pipe and carb). I can try to scan/post the dyno graphs if anyone is still interested.
The community would much appreciate it i'm sure.
Please do. It would be interesting to see and compare.
If you don't mind me asking, what did you end up paying for the bike?
My bike has just a few more mods than the original 351. I've only managed to rack up a little over 400 miles on it over the last few years unfortunately. I've toyed with the idea of selling it hence my question.
Thanks,
Michael
#29
My first ZRX was a 99' 1100 that I went a little overboard on(swapped in a 1200 engine, did a 2mm overbore(1224) and turbocharged it. From what I remember, it put out 241hp and 177ft lbs torque at 14 lbs. of boost. Next was a 03' 1200 that I kept fairly stock(piped/jetted). The 99' got parted out and the 03' sold. The proceeds went to one of my current rides...a 05' BMW K1200S. If you do some digging on the ZRXOA board, you can find 1224 turbo build thread.
#30
Well, I scanned the dyno sheets but was unable to figure a way to upload them to Photobucket, so I took pic's of the sheets and uploaded the results that way. Sorry for the poor pic quality.
Run #1= stock bike. Results: 19.30 hp and 13.12 ft. lbs. torque. Run conditions 74.86 deg., 30.15 in-Hg,humidity 16% SAE: 0.97
Run #2= Big bore only. Assuming this means stock pipe and jetting? Results:24.68 hp and 18.75 ft. lbs. torque. Run conditions: 76.09 deg., 29.81 in-Hg, humidity 22%, SAE: 0.98
Run #3= Big bore & FMF Powerbomb header/Q4 muffler. Results:28.30 hp and 20.04 ft. lbs. torque. Run conditions: 75.88 deg., 29.83 in-Hg, humidity 22%, SAE: 0.98
Run #4 Big bore, FMF Pwerbomb header/Q4 muffler, carb(was told the bike has a Mikuni pumper carb on it). Results: 29.51 hp and 21.28 ft. lbs. torque. Run conditions: 78.60 deg., 30.15 in-Hg, humidity 14%, SAE: .097
