KLX300 Header Versus KLX 250S
I just received a KLX300 header pipe (stamped KHI E033) via craigslist, described as "about 6 years old."
I was suprised to find the pipe diameter to be the same as my `06 KLX250S header (stamped KHI E045), 1.255" on the OD in the straight section.
The 3X M6 heatshield mountings looks exactly the same between the two.
The only difference I see is the KLX300 pipe projects back 1" more and flares out to a slightly larger diameter of 1.510" versus the 250's 1.383" diameter, to accept a larger diameter and 1" shorter muffler pipe.
There is really no volume difference in the two headers, until you get to the muffler clamp back.
+1 Search function sucks. Better than nothing, but not great. I just searched "high altitude" the first three threads that apparently fit that search are the Bent handlebar-new exhaust thread, the what engine oil do you use poll, and the HOTD sticky. Ooooh I haven't looked at the HOTD sticky in awhile, I guess search works ok.
I'm sure you could hanglide where I was headed. (none for me thanks LOL) I think I actually searched "High altitude jetting" when preparing for the trip to Colorado. "Jetting" was too broad. I think I ended up searching "colorado" because I knew I had read posts on getting bikes running right out there in the mountains.
