KLX300 fork springs fit '09 KLX250S.
Gave it a shot and they fit fine. I got the Race-Tech .46KG, P/N: FRSP 3946. Diameter of the whole spring is the same, as far as I could tell but, they are about 2 inches longer than the stock springs. Even so, they weren't very hard to install. Also, the extra length did not cause any issues with the various cable lengths as I thought it might. Took the bike for a trip to the local dollar store and, she rides great, nowhere near the dive I got before. The springs were $93 at mawonline.com.
I don't know...I'd bet installing 2" longer springs that are not designed to work that way will make the proper spring preload way out of whack. I kind of doubt you'll ever get all your travel either. It's no wonder you didn't get the dive you had before. Did you remove any spacers or anything like that?...or just stuff the 300 springs in there?
I used some Race Tech springs for a 300 in my '06 250. They were 15mm shorter than the 250 springs, but the springs are designed for the same travel as my 250. Once proper spacing and preload are achieved, the springs work excellently. That's not the case with 11" springs stuffed into a 10" fork with no other issues addressed.
I'm not sure why so many people get locked into Racetech like it's the only brand around.
Moto Pro has the specific spring length for the 09 KLX250S in any spring rate you want.
Glad to hear you THINK it worked-out, but 'just sayin.'
Not sure if the 09 uses spacers along with the shorter, stock springs, but if they're in there, I'd probably remove them before going to longer springs. As it stands now, you might bottom-out against the spring, which is not a good thing.
Newblood, there are two spacers inside the cartridge tubes that you need to remove if you are going to use the 300 springs. I went through the same thing, so I returned the RaceTechs and ordered MotoPros of the correct 09 length. I didn't want to go to the hassle of taking apart the cartridges. You can hear the spacers sliding in there if you take the shocks completely apart.
The stock fork and shock springs are quite soft. For anyone over about 175lbs that rides fairly hard it is worthwhile to increase the spring weight. This also reduces the amount of dive in the front end when braking. Kawasaki only makes one spring weight, so motopro has them made. Motopro seem to know more about the fact that the 09 KLX is different than the 07 models, so they seem to be the most popular, as they actually get you the correct spring length for the 09.
spain
Greetings everyone!
I have an EFI klx250 one years and I've been looking for the fork springs. PRO MOTO I searched web but unfortunately have not found either. Someone has actually seen or bought these specific shorter springs for 2009/2010?
MOTO PRO ref?
Thank you very much. We have a problem with the fork springs.
MOTO PRO ref?
