KLX300 CDI
RE: KLX300 CDI
Gary, when you say it won't start - you haven't overlooked the clutch lever/kickstand lock-out circuitry have you? (Probably not but I had to ask)
RE: KLX300 CDI
Some new info... Check out Tremor38's comments in the thumpertalk thread:
http://www.thumpertalk.com/forum/sho...d.php?t=406991
RE: KLX300 CDI
I'm sorry, I have failed us. I tried most conceivable combinations on hooking the 300 CDI up and couldn't get it to work. At one point I was blowing my main fuse every time that I turned the key on. (that was a little scary!) So I have decided to wait for more (or better) information before continuing this pursuit. I havn't given up.....just being cautious.[sm=headbang.gif]
RE: KLX300 CDI
No problem vfrpilot - you definitely pushed the boundaries, sometimes it works, sometimes it doesn't, but you always learn something new in the process. Sometimes I'll do something like that and like you not succeed right away, but sometime later get an "aha" moment where I suddenly understand what went wrong and then go back and make it work. At any rate, thanks for giving it go - takin' one for the team right there!
RE: KLX300 CDI
ORIGINAL: Bad Bear
I was just wondering why you would try this seems it would have about the same unit. Have you heard of it being a better performer? I'm not saying you shouldn't try it just curious what made you think of it.
I would guess you would use the same plug as a KLX 300 uses as long as its the same size and length into the head.
Let us no if you notice any difference.
#30
RE: KLX300 CDI
ORIGINAL: deej
Parts swap?
Parts swap?
