KLX300 "06" & KLX250S "06" FRONT SPROCKET INTERCHANGABLE?
Old 05-31-2008 | 12:54 PM
tremor38's Avatar
Default RE: KLX300 "06" & KLX250S "06" FRONT SPROCKET INTERCHANGABLE?
Well, that's because you keep changing your jets, when all you need to do is cool them down[8D] Are you a red head, by any chance?
ORIGINAL: 09KLXowner
fingermullet- installing a jet kit and dialing it in is way different than whether or not a KLX300 front sprocket will fit a 250S.
Old 05-31-2008 | 05:23 PM
I'm pretty sure I know what I'm talking about.
If you say so.
Old 05-31-2008 | 08:30 PM
09KLXowner's Avatar
Banned
so finger- you never answered my question. In your opinion, will a KLX300R front sprocket bolt right onto a KLX250S? If you read my first reply, I said no. Are you saying I'm wrong? Just want to be sure where you stand on this one. Maybe you really don't know.[&:]
Old 05-31-2008 | 10:30 PM
You are one odd cat. You got the Napoleon Complex don't ya.
Truth is, I don't know if the klx300 will or will not fit on the 250 ...... I've read about it numerous times and all said it does not fit, however I have no direct experience saying it does not. I don't even know if the splines are the same, maybe they are maybe they are not? Do you know???
Have you tried a klx300 sprocket on our lil klx? You seem to be so sure in your opinion.
Some things I do know
The Sprocket Specialist 13t listed on this forum fits
A stock klx 300 cylinder and piston will bolt right up
A stock klx 300 kick starter will bolt right up
A 340 kit as listed on this forum will bolt right up
A FCR 35 fits no problem and is worth the effort
A klx 300 fuel tank fits no problem except you have to use 300 rad shrouds
A Baja Designs headlight fits no problem
A Baja Designs led taillight fits no problem
A Maier rear fender fits no problem, well a little cutting
KTM turn signals fit on the klx better than the kawi stock ones
Moose Raptor Bend bars fit perfect along with their bark busters
A Guts Racing High Seat Foam and Cover fits perfect
A Muzzy Full System will bolt right up...and if you tweak the mid pipe .... no mods reqd for the pass foot peg
A k&n air filter for a klx300 fits perfect
A Blue Sea systems Circuit Reset makes a great starter button replacement
Stock KTM Mirrors fit our klx perfect
A Renthal 49 tooth rear sprocket will fit without modding the lower chain guard
A 100 watt halogen H4 headlight bulb works fine and will not drain the batt
A Utah Skid Plate fits perfect
MotoPro Springs and Valves are worth every penny
A Kenda 120 Trakmaster II is the biggest you want to put on the klx but a 110 is better
Ok, thats enough, the point of my post was to question why you always try to belittle people with stupid snide comments....get it.
Old 06-01-2008 | 04:50 PM
09KLXowner's Avatar
Banned
yeah i know for sure it won't fit. you didn't, and that my friend was the point of MY post. so my stfu to you was validated.
canehdian_guy
03-30-2015 05:03 PM
cjbiker
03-25-2013 11:56 PM
WestOzKLX
09-08-2008 03:14 PM
35racer2
04-19-2008 02:03 AM
Coastie_Rider
Ninja ZX-7R
09-24-2006 09:42 AM
