KLX300 "06" & KLX250S "06" FRONT SPROCKET INTERCHANGABLE?
RE: KLX300 "06" & KLX250S "06" FRONT SPROCKET INTERCHANGABLE?
if you go to the Kawasaki parts site; they are different. I'm pretty sure it has to do with the output shaft and different gears.
I changed the rear instead....... the front was a little noisy and wore the chain faster.
so when I bought a new chain I just thought what the heck........ I guess the rubber on the fronts there for a reason so I went with it.
as it turned out formy trail speed- 2nd and 3rd is more usable with a 47 rear (if I really need to gear down,I still have that option to go back to the front with the 47)
ORIGINAL: djmerullo
ARE U SURE?????????
ARE U SURE?????????
ORIGINAL: 09KLXowner
you're a newb. this has been discussed in great length around 2.5 years ago. yeah, I'm sure. but hey, if you have doubts, try it yourself.
Ha ha always comical on the KF
Hey TALLENif your looking for a 13 tooth front sprocket I can tell you that the Moose sprocket part number 1212-0073 fits andworks. $17 from a parts unlimited dealer. There are others that fit, you can try searching on here for other options.
I've got a 46 JT Sprocket that I will mount once my new chain shows up (back ordered). For $33 buck in carbon steel, it seem hard to pass up. And, since this thing is too scary for 80MPH highway speed, more low end seemed in order at the expense of some more RPM's on the 50MPH runs to work.
ORIGINAL: Finger Mullet
Just like jetting the carb....yet after 2.5 years you are still posting threads about it and can'tget the jetting right on your bike. Who's the newb?
btw, the jet kit is fine now. it was fine in the first place, it's just that my ocd convinced me to tear into it. if you check my initial post after the dj install I said it was perfect. but to me, nothing is quite perfect so I keep searching until I get it. I got it tonight, or as close to it that I can come.
