KLX250SF no digital display/won't start
Old 07-25-2014 | 07:45 PM
Timmyk294's Avatar
Default KLX250SF no digital display/won't start
I went to start my '09 KLX250SF the other day, I turned the key on and the digital display light up like normal. When I hit the starter button, I heard a "click" then the display went off and the bike would not start. I checked the fuses and they are all good. I pulled the battery and put it on the charger, it showed it was fully charged and the volt meter showed 13.1. Hooked it back up and still no display. Any ideas? It is the original battery and I've had no issues thus far.....
Anyone else ever experience this problem?
Old 07-25-2014 | 08:54 PM
wildcard's Avatar
double check grounds and did you pull the fuses out to check them ? ive had blown ones that looked okay still in the holder.
Old 07-25-2014 | 09:44 PM
Timmyk294's Avatar
Yes, I pulled the fuses out and checked them. I'll check the ground connections. It's the little "click" I heard that concerns me!
Old 07-25-2014 | 10:22 PM
NorCalKLX's Avatar
Sounds like a bad battery or connection. Check the battery with a volt meter while you try and start it. It's possible the battery fails under load.
Old 07-26-2014 | 07:03 PM
zl PINHEAD lz's Avatar
just out of curiosity, is this a carbed or an EFI model?
Old 07-26-2014 | 08:22 PM
Timmyk294's Avatar
It has a carb.
Old 07-27-2014 | 05:25 AM
GBAUTO's Avatar
I would suspect that the battery is failing under load and isn't capable of providing sufficient voltage when you try to engage the starter motor. Five years is a long time for a motorcycle battery but I have had OE Yuasa's that have gone longer-my 06 gixxer is still running on the original.
IGoFast1589
06-25-2014 06:37 AM
pvr02
Ninja 250R
07-25-2007 01:19 AM
deej
01-23-2007 08:10 PM
mackshackgabe
01-17-2007 08:24 PM
jlm1991
10-23-2006 07:21 AM
