klx250sf need quick turn throttle and qs
I am looking for a fast turn 1/4 or 1/5 for my 250sf....how do you install one in the stock assembly with the starter and kill switch? Someone please give me a solid explanation.
Next where do I get a 15t front sprocket and approximately how much will the rpms drop at a given speed?
Will I need to change the chain?
Also where do you recommend I purchase Avon distanzias for the 250sf. Im having trouble finding the right sizes.
Thanks guys it will help a bunch!
Also where to buy a tm36-68??
It is so i do not have to turn 2 full rotations to go from idle to WOT...I have to reposition my wrist in order to get full pull. Does installing the tm36-68 change the amount of rotation to open the carb fully?
The klx250sf has a different throttle, I am looking to shorten the pull by about 30-40%. It will make it much quicker out of turns when going from engine braking to exiting wot. Usually geared up but it annoys me. Does the tm36 shorten the pull?
The throttle rotation is very long on my S model too. I haven't measured it but I feel like an idiot when merging onto the freeway and as I shift gears I have to do this big exagerated twist to go from throttle off to full throttle. I feel like a comic book kid. Elbow way up in the air and then way down by my hip.
lukelebras
06-17-2014 02:48 AM
