Klx250s melted piston help?
#121
Originally Posted by Ranger Ron;460215 [I
Usually with a big bore, you don't have to make much of a change with the main jet. The reason for this is that with a larger displacement more air is being drawn into the engine for the same piston speed. This increases the intake velocity. The increased intake velocity adds more fuel automatically.
If I remember correctly, the oem main jet for my 2006 was a 118. With the 351 a 120 main works best for me. [/I]
Ron
Ron
You've probably did other mods as well which would have normally required richer jetting, making the 351 w/ 120 main even more surprising.
I have found that if one is able to increase vacuum draw across the jet orifices in the carb floor thru one mod or the other, it is possible to find your jetting is now too rich. I have had to back off a size on pilot jets because of it in the past on other m/c engines.
So maybe your other mods: intake and exhaust were just the right combination and were getting the fill benefit of the 120 main
