klx250s 09 jetting question
Old 06-26-2009 | 06:03 PM
patatewz's Avatar
Default klx250s 09 jetting question
Hi!
I just receive my uni filter, with a Jet kit and a q4 pipe and headers.
SO now i need to rejet my bike. Im a 100 feet from the sea in montreal canada.
So i need to know what is the best jestting setting...
tanks a lot for your help
Old 06-26-2009 | 06:39 PM
RDHJ's Avatar
http://hmfracing.com/forums/showthread.php?t=1617
take a look at that...I have a 130 main jet in my 2006 with stofk exhaust with a hole drilled in it and it runs strong, so i'm under the impression that an exact jet size is not necessary, just need to be close to the optimum size. Didnt your jet kit come with suggestions?
Old 06-26-2009 | 08:11 PM
patatewz's Avatar
yes with some sugestion... but i dont see any information for the sea level im at.
(exucse my poor english im a french canadian) thanks for the information!
Old 06-27-2009 | 01:16 AM
WestOzKLX's Avatar
Go for the biggest. I suspect #132. See how she runs. Richer is always better than leaner. With a full pipe and filter at sea level you should run a "decent" size up from stock. I'm running #138 main and #38 pilot at sea level to 1000 feet. Runs great.
Old 06-27-2009 | 11:42 AM
patatewz's Avatar
ok ... but in my dj kit i just see main jet and no pilot jet.
So i need to order one pilot jet alone?
Old 06-27-2009 | 12:00 PM
WestOzKLX's Avatar
Yes!
If you're at sea level then I'd up the pilot jet to a #38 with the #132 main jet. Under $5 for a Keihin #38 pilot jet.
Old 06-27-2009 | 12:25 PM
CousinLarry's Avatar
When my bike had the 250 and the FMF Q4/Header, foam filter, lid removed - my jetting was #128 main, stock pilot, DJ needle at 4th clip I believe, and like 2-2.5 turns on the fuel screw.
But when I tore it down the piston and valves had excessive carbon buildup so maybe even that was too much. Ran great though!
Old 06-28-2009 | 12:55 PM
patatewz's Avatar
hmm ok... and to much carbon = too much fuel too less air?
and your 128 main jet comme in the dj kit?
So if i try the same setup as you, i will make carbon in my cylinder? You live at wich altitude?
Old 06-29-2009 | 06:12 PM
patatewz's Avatar
i try to get the 38 or 40 pilot jet but my dealer need the part number... anyone know where i can find it? thanks!
Old 06-29-2009 | 06:45 PM
Newblud1775's Avatar
Hey there, patatewz, try these: 92064-1050 #38, 92064-1108 #40.
Quick Reply: klx250s 09 jetting question
