KLX250 Rear Brake Lever Mod (Lowered @ 3/4")
Old 03-24-2012 | 01:04 AM
rgoers's Avatar
Default KLX250 Rear Brake Lever Mod (Lowered @ 3/4")
I had decided I was going to attempt to lower my brake lever, so that when my feet are flat on the pegs, I'm NOT applying the rear brakes. I went ahead and ordered another lever from eBay. I bought it for $15 (shipped), so I figure I have nothing to lose it I mess it up.
So, my brake lever arrived a couple days ago. I had this Friday off, and I decided to work on the brake lever mod (instead of taking the sleds out for one last ride).
I took pictures along the way, so if anyone else wants to copy my mod, it should be real easy to follow what I did.
Here are few pictures of my prep work. First one is just the new pedal. Then there are a few of the cardboard template, so I could get an idea of how much metal needed to be removed to give the correct amount of drop.
Attached Thumbnails KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07551_new_lever1-custom-.jpg   KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07553_template1-custom-.jpg   KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07554_template2-custom-.jpg   KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07555_template_cuts-custom-.jpg   KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07556_template_modded-custom-.jpg
Old 03-24-2012 | 01:09 AM
rgoers's Avatar
So here I laid the template over the pedal, to see how much of a difference it was going to make. Then I marked the cut location, and used an angle grinder to remove the metal. I closed the "V" cuts, then did a test fit on the bike.
Attached Thumbnails KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07557_template_overlay-custom-.jpg   KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07558_lever_marked-custom-.jpg   KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07564_new_w_cuts2-custom-.jpg   KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07566_new_cuts_closed2-custom-.jpg   KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07569_new_fit_on_bike1-custom-.jpg
Old 03-24-2012 | 01:16 AM
rgoers's Avatar
Okay... next, I notched the cuts to help with weld penetration. One more final fit, where I tweaked the angle of the lever pedal to make sure it was just right. I hit both sides with the welder (Please don't make fun of my welds. I'm not a professional welder... I don't even play one on TV).
I found this wonderful paint at Lowes that matches (almost) perfectly! I was amazed at how close it is to the Kawi color and texture. Simply amazing!
Attached Thumbnails KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07570_cuts_vd1-custom-.jpg   KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07572_final_fitment-custom-.jpg   KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07575_front_welds-custom-.jpg   KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07580_paint3-custom-.jpg
Old 03-24-2012 | 01:24 AM
rgoers's Avatar
And finishing up... Here's the old and new (modded) together. Mod on top... old lever on the bottom.
Then there are the before and after shots. I tried very hard to match the angle of both pictures to show the difference. In the pictures it doesn't look like a lot. In reality, it dropped the lever about 1/2 inch, which worked perfect for what I wanted.
I did some riding to test it out, made a couple adjustments at the rear cylinder clevis, and it's just perfect now. Well worth the couple hours I spent fiddling with it.
Attached Thumbnails KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07581_new_and_old-custom-.jpg   KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07561_old_on_bike2-custom-.jpg   KLX250 Rear Brake Lever Mod (Lowered @ 3/4")-dsc07584_on_bike3-custom-.jpg
Old 03-24-2012 | 09:45 AM
jeffward's Avatar
Congratulations!
You also gave me some ideas.
Old 03-24-2012 | 02:59 PM
Well done! Very nice work. Welds look 3x better than anything I do with my harbor freight special welder Thanks for posting. I adjusted mine way down with the clevis, but this is a good way to get even more drop if needed.
Dan
Old 03-25-2012 | 03:24 AM
punkenduro09's Avatar
thats rad you did this. a lot of riding to me is being one with the bike, and little things like this make a world of difference. hope it helps, let us know how it works out.
Old 03-25-2012 | 03:41 AM
Borg's Avatar
My clevis adjusts far enough to prevent this...
Does yours not adjust that far?
Old 03-25-2012 | 04:02 AM
whyzee's Avatar
+1, for free,too.
Old 03-25-2012 | 04:13 AM
rgoers's Avatar
My clevis didn't do it for me! Obviously, I went that route first. I had it cranked as far as it would go, and it wasn't near far enough... hence the mod.
I rode some off-road today, and it was *wonderful* to only be applying the rear brake when I wanted to, instead of every time I stood up.
Quick Reply: KLX250 Rear Brake Lever Mod (Lowered @ 3/4")
