KLX250 Front Brake Line Alternatives
Old 11-29-2021 | 05:17 AM
klx250-karl's Avatar
Default KLX250 Front Brake Line Alternatives
Hello,
Apologies if I've posted this in the wrong Forum, as I have a 2005 KLX250 (which I don't believe is a 250S).
I was still hoping I could get some help on finding alternate options to the OEM Front Brake Line.
I am hoping to get a stainless steel line that replaces the original brake hose as well as the hard-line that runs under the caliper (aka, a line with banjo bolts either side).
What other model KLX or KXs would share similar length and fitting configurations as what's required to fit the 2005 KLX250?
From looking at diagrams it seems either the 09+ KLX250S or the 07+ KLX450R might fit my bike?
Any help is appreciated.
Also, I am located in Australia, so getting a line made up by 'Bill' probably isn't an option for me.
Thanks!
Karl
Old 11-29-2021 | 11:18 PM
KLX650 is very likely the same. They use similar forks and all. Model years started in 1993, only ran to 1996 in the U.S. not sure about Australia.
Old 11-30-2021 | 12:15 AM
Thanks for the reply! You're right, looks like the 650 has an identical brake line set up as the 250. Unfortunately, there was no stock of those lines either.
I decided to go for a KLX450R line, that way I can go straight to the caliper and bypass the hardline.
I'll post here to let people know if it worked once I install the part.
Old 11-30-2021 | 10:42 PM
I have a print that the KLX650 guys used to do what was called the CR wrap.
It would wrap around behind the fork.
Old 11-30-2021 | 11:23 PM
Awesome thanks. Yeah that's the plan. I'll see how it goes.
Martindktm
10-14-2020 03:01 AM
vlodpg
03-05-2019 01:13 AM
asheville thumper
01-12-2016 06:38 PM
pt195
09-13-2009 05:38 AM
Cowboy 6
08-20-2006 09:21 AM
