KLX250 EFI big bore - is there an actual EFI solution?
292CC Cyl with 260CC/min inj is like original 249Cc cyl coupled with 220CC/min inj, adding free flow exhaust with KDX200 snorkel and a twin air filter and slightly more fueling is needed.
A 2,5kOhm NTC thermistor in series to the original IAT NTC fitted inside the airbox fool the ecu thinking a colder air is actually sucked (near 10°C colder) adding a little more fuel to the mixture (5%).
Your idea is absolutely brilliant!
Do you have a picture of your installation? If you don't, that's ok as I think I get your idea that the thermistor ~also~ has to be within the airbox along with the original one in order to ~also~ sense the intake air temprature. I'm going to do this just like you did.
Thanks again,
Greg
Thank you so much for responding.
Thanks again,
Greg
Thanks again,
Greg
you are right, NTC must be put in the airbox, i placed mine on the side before air filter, it's fitted through a drilled 5mm hole then sealed with RTV silicone.
The closest Thermistor I can find is 2K OHM. It's nicely encapsulated and has leads on it. Would that work? Do you know what percentage mixture richening that would yield?
It will give a slightly less enriching , nothing to worry about.
Why not use an adjustable 5ohm unit?
https://www.mouser.com/new/bourns/bo...ters/#Bullet-2
Since I already bought the thermistor I'm going that route as it adjusts for intake air temperature.
