KLX250 a bit heavy?
Old 03-01-2007 | 12:25 AM
tintman's Avatar
Default KLX250 a bit heavy?
Has anyone actually weighed their KLX250, mine has the rack, chain guard and de-icer removed along with a lighter aftermarket exhaust and it hit the bump stop on the scales at 130kg(286 lb) with oil and 2 litres (.52gal) of fuel. I did this with some bathroom scales on top of the lift stand so not the most accurate method, has anyone weighed their bike more accurately.
Old 03-01-2007 | 01:19 AM
double d6's Avatar
Default RE: KLX250 a bit heavy?
Kawasaki lists the 2007 KLX 250s @ 262 lbs.
So, your scale must be off, because it would seem thatyour bike would be lighter.......
With a full tank 1.9 gallons. A gallonweighs 8.34 pounds so that's................
15.846 or so...........should still only be around 278 ....................
But what do I know. I can tell you that a friend of mine has trouble with his drz400, I on the other hand lift the bike up with ease.
Dave
Old 03-01-2007 | 01:48 AM
bryantjt's Avatar
With a full tank the KLX clocks in at 292 I think. I know what the title says but that is extremely optimistic even for dry weight. Don't foget this bike has liquid cooling and dual radiators.
Old 03-01-2007 | 02:07 AM
double d6's Avatar
And brake fluid, oil and DIRT..............etc.
Yeah, I'm way off....So I have been lifting more than I thought.......nice!!!
Old 03-01-2007 | 02:25 AM
Don't forget the coolant - probably a liter or more in there, good for a few more lbs I'm sure.
Old 03-01-2007 | 02:28 AM
i believe tremor has weighed his... could be wrong.... i think it came in at 272lbs...
Old 03-01-2007 | 03:06 AM
EvildoerZX10R's Avatar
I read where someone weighed theirs. I know most manufactures are very optimistic with their dry weights. I would think the klx if rated at 262 dry from the factory would be at least 15-25 pounds more with fluids and battery in the real world.
Old 03-01-2007 | 04:07 AM
motoguy128's Avatar
Dry weight exclude ALL fluids. So 1.6 quarts of oil, 1.95 gallons of gas, 1.4 quart of coolant, 0.3 quart of brake fluid, and almost 1 quart of fork oil (maybe less) So just about23-24lbs of fluid... I didn;t look up hte specific gravity of each oil. I used about 8lbs/gallon.
262+24=286
Old 03-01-2007 | 04:35 AM
That sounds about right to me. If you want it exact just weigh it on some better scales it really doesn't sound like yours are off by much.
Old 03-01-2007 | 05:12 AM
tintman's Avatar
Wow sure adds up, no wonder a mates CRF450X feels lighter. I probably notice it more being a 75kg hobbit.[&o]
Quick Reply: KLX250 a bit heavy?
