KLX250 to 300 Upgrade Review
RE: KLX250 to 300 Upgrade Review
ORIGINAL: tremor38
That's actually the official procedure used by Kawi. I've read about more than a few people poking a hole in their radiatior while changing the jug just because they didn't want to spend a few extra minutes changing the rad and anti-freeze...not worth the risk in my book.
ORIGINAL: Nobrakes
It would be kind've hard to do a bore upgrade without draining the coolant.
ORIGINAL: tremor38
That's actually the official procedure used by Kawi. I've read about more than a few people poking a hole in their radiatior while changing the jug just because they didn't want to spend a few extra minutes changing the rad and anti-freeze...not worth the risk in mybook.
i thought that our engines were the 300, except they just had a sleve in it to make it the 250? pop the sleve out and get a bigger piston?? i'm not really sure, garenteed nobrakes or someone else will have a solid answer
ORIGINAL: rkutzner
Who has used the stock carb for either the 300 or 330 and what did you end up with for jetting ? Seems I've heard most who go to the 330 go to a pumper carb. If that is true, that is an extra cost that must be considered.
I find a very strong low to mid range, but lacks the zip it used to have at at 9-10k rpm in the upper gears.
ORIGINAL: pie4foou
Not sure I agree with that. Therehas to be agood reason why that isn't being done. My guess is, just like a car, boring too much will result in too thin a cylinder wall, possibly getting too close towater or oil passages. Don't quote me on this, just throwing out a doubt !
The KLX250 cylinder needs to be bored out & replated or install a sleeve to make it into a 300 or into a 330 it isnot a sleeved cylinderin the stock form.
It is not worth boring and replating the 250 cylinder to 300. By the time you pay someone to bore it and then have it re-niskal plated you might as well just buy the 300 cylinder to begin with. If you want to go to 331 for less money than send your cylinder to Bill and have him bore it and then sleeve it to 331. He can also sleeve it to 300 but it will cost about the same and would be dumb not to just go to 331.
No the 250 cylinder does not have a sleeve that can just be removed to go to 300. It is a different cylinder than the 300 and is also niskal plated, no sleeve. Remember in mostcountries other thanthe US the250cc version klx never saw a stop in production.
As far as pumper carbs are concernedI am sure taking the klx to 331 with the stock carb is a major increase but I read some where that a klx300 with a pumper will out preforma klx331 with the stock carb. But this all depends on what type of riding you will be doing. If you are going mostly street I would go 331 with the stock carb. If you are mostly dirt, get a pumper.
Mileage sometimes doesn't make sense. The klx, bumped to 300 like described, gets 45-50mpg? My 1200cc Buell gets 50mpg. Makes around 85 rear wheel horses/100+ at the motor. It doesn't seem fair; the KLX should get more mileage! Heck, one of the guys at the local shop has a tricked Hayabusa he dragraces, and it gets 40mpg when he's cruising and not on the nitrous...very aerodynamic though in comparison!
doc
doc
