KLX250 2010 rearshock rebuild,,
I know TNC has worked on his rear shock. From what he says, it is pretty straight forward. He'll probably chime in. If you have any other specific questions, I would post them up. I think your local Mcy shop will have Nitrogen for charging the shock.
Dan
Dan
Racetech in Singapore are sending me one,, In the meantime he reccomends using a hypodermic needle, to release the gas,,
So that is what i did, Inside there is a self sealing rubber system , so i will need the right tool to rebuild.
Any way i have to go to work, so will continue when i return.
Will post some pics incase you guys have not seen this type before..
Cheers
Cheers
