KLX250 09 - Rear Fender Alternatives
Hello,
Does anybody out there know of any alternatives for the rear fender for the
09 KLX 250, I am thinking of modifying the original back fender, by cutting the long mud flap part of the fender off.
But before that i was just wondering if there might be after market back fenders out there, that aren't to costly.
Just thinking of the potential for resale later on, if i can buy and swap the fender with and aftermarket one, so i can put the original one back on at a later date.
I used the edge tail light system. Perfect fit.
http://www.wheelingcyclesupply.com/s...ory&cat_id=128
yep, the edge tail light has a small white led for the tail light.
I started by cutting my fender and fliping the licsense bracket, but recently had that get ripped off on a trail.
I just finished installing the Edge tail light kit for a 09 KLX250s from wheeling cycle supply, and some led turn signals from Procycle.
Much better now
Much better now
When you say Procycle do you mean these guys http://procycle.us/ | http://www.procycle-online.com/
What was the exact model of flashers you purchased ? Did you require a inline resistor ?
for them to work ?
Cheers
D.
yep, that's the place.
Crash Advantage LED Turn Signals, part# 60-1916C, the C is for clear but they sent me the amber ones instead.
Yes I also had to get resistors. got em from same place.
For anybody in OZ looking to buy one of these .... Here is an australian connection for the same product.
http://www.stevecramerproducts.com.a...=934&B=33&BT=1
I trimmed off some of the sides and I cut my fender higher up than most people on here... for the exact reason as above ^^ if you just flip the bracket and cut you run the risk of sucking up your plate under heavy suspension load, and its a bit flappy and loose.
Here's mine (with the turn signal tuck I did)
