KLX high/lo beam separate elements or
Does hi beam have both hi and lo coming on together?
I've tried to look when my D Tracker light is on, but it's just blinding.
I don't ride at night usually, so I am thinking about using the hi position on the switch for an Off switch position if I disconnect that line inside the switch or near it..
I cut the hi beam wire inside the switch yesterday and can tell that not having that powerful headlight draining power at the same time I am starting it is a big plus.
Using the hi beam position as an Off switch may be low tech, but it was quick and easy and still keeps the on/off choice handy at my left thumb.
