KLX fan assembly
KLX fan assembly
hello
I have KLX 250D
those bikes (250D) dont come with fan at all.
I bought fan and I dont know where to connect the (+) and (-) wires
here is my wiring diagram:
Photo1678JPG - UpF.co.il
this link to download my wiring diagram...please help me
I have KLX 250D
no I dont have the sensors and relays...
i just want to connect it directly to voltage source of 12V through on\off switch
but I just can't find the 12v wire...
I can't take voltage from the CDI unit (that kind of thing wants to turn off the bike)
my only option is from the yellow wire that goes to the regulator, and it gives my only 3V .
is it normal ?? maybe my stator is weak??
Remove the seat, look towards the back and locate the little fuse box (has like only 3 fuses)... splice into the heavy gauge wire going into the fuse for the headlights. Make sure the splice is BEFORE the fuse and on the proper terminal side so you are not drawing current through the fuse for the headlight. Install an inline fuse with you splice for safety... this is your + it will go "hot" only when the key is turned on now. Negative - naturally is ground... ground it wherever your little heart pleases. Now you will be able to wrap tape around the inline fuse and the fuse box with electrical tape and have a neat and presentable look for you new "fuse box".
Use zip ties, heat shrink, crimps as needed.
