KLX Control Mods
Old 07-24-2022, 08:55 PM
Nigel's Avatar
Turns out the bolt is a cylinder head damper.
Old 11-13-2022, 05:40 PM
bmart's Avatar
Originally Posted by Nigel
Hey could post a side shot, like the one I attached. The setup I have a fairly comfortable for trail riding, but I am always open to trying something if it is better. I currently have renthal bars with much less sweep than stock and zeta offset risers. I would like to get an idea of where your ATV bars sit compared to what I have. Thanks.
Don't think that we don't see the turbo 3.8L!
Old 11-15-2022, 11:44 AM
durielk's Avatar
CYLINDER HEAD DAMPER???? What is that? BS!
Those ATV bars have way more sweep to them, I like it!
Old 11-15-2022, 12:53 PM
Yeah, I kind of wondered when I saw that, what would it be damping? I was wondering if the fastener was really just covering a hole that was necessary for machining of the head. The work is done then the hole is plugged with that fastener. After all, there is the flat machined in the head and it would be one location point to secure the head for machining or possibly allowing access to machine a passage in the head. I'm probably wrong. Maybe some day I'll remember to go look at the bike.
Old 11-15-2022, 01:34 PM
durielk's Avatar
I don't know, Nigel, did you ever have head work done?
With the head bold holes, why would you be putting a hole in the side of the head? But, one never knows until he's done it!
Old 11-16-2022, 01:01 PM
I was thinking it was a factory machining process. Perhaps the machining process would need some support or location on that area outside the cam drive tower. Just a thought. I know there are places where machining is done and holes plugged with either some sort of ball insert or a threaded plug, like in oil line machining. Any machining requires a part be located.
Old 11-16-2022, 03:46 PM
durielk's Avatar
If you check the new 300, that bolt is a change from my 07. So there are a lot of them around, I thought it was added after mods.
Old 11-17-2022, 01:33 PM
Really I don't know, so your guess is as good as mine until someone actually finds out what it's there for.
Old 11-18-2022, 10:16 AM
Nigel's Avatar
Kawasaki calls it a damper bolt. Since the head has been around since Jesus was a baby it is probably not for mechanical integrity. With more and more stringent noise requirements to meet euro5 or EPA, it may damp out some acoustic resonance as a guess for example. Kawasaki knows why they did it and why they call it a damper bolt.
Old 11-18-2022, 10:22 AM
Nigel's Avatar
Quick Reply: KLX Control Mods
