KLX 351 Kit Install
I installed Barnett springs with the original clutch. It slips a little but only at WOT which I don't do much of. I might look into shimming the springs to increase the clamping force a little. Interesting that at 800' you were so rich. I run a DJ140 main jet with 2n needle position and get 65mpg all the time. Could be a little lean or rich but I can live with the mpg and it runs good.
I use an EBC DRC212 with Barnett spring 501-25-06043. I run Rotella 15-40 dino and it does a good job. I also remember that the 351 seemed to have a stronger vacuum signal to the carb so it did run a bit rich on jetting for the 250.
Re: Stronger vacuum with the 351, I was thinking the same thing. The bike was drowning in fuel with the only changes being a single washer under the e-clip and one main jet larger, crazy.
It's going to be a balmy 7 degrees C tomorrow, I should be able to put 50-100km on it before I freeze
Iirc on another site planet klx a recommendation on using kx125 plates (not sure what yr) helps. I'm running that ebc clutch kit w Barnett springs and still have slippage in 4,5,6 if on the street/wfo. I was going to try to use washers to preload the springs but haven't seen anyone do that yet so I'm hesitant. But I will try the kx plates next.
Wonder if there are any compatable springs besides the Barnett replacement springs. I remember using cr500 clutch springs in a 250 (3 cr500, 3 stock oem) and that helped but lever pull was affected as well.
I was doing a bit more reading and found that you can use three of the springs built for our bike (# 501-25-06043 ) and three heavier #501-40-06017 springs. Supposedly the latter are 38 pound springs. Does anyone know where to find a list of Barnett's spring specs?
I would replace the clutch plates, IMO they retain oil and you will never get it out no matter how many times you change the oil. I would not recommend using other than standard oil, it just works, what else do you need. Going to syn oil has no advantages on the mileage/time for a dirt bike.
I ended up breaking one of the bolts holding the springs in today so I'm definitely ordering new clutch plates. I was pulling away from a stop sign and it went, I immediately shut it off. I got the bolt out and put three stock and three heavier springs from a YZ 2 stroke I had lying around until I get the Barnett springs and new clutch plates. I have ~130km on the BB kit now.
No issues with the piston/cylinder at all. I did have the slide stick open in the carb today after I pinned it a bit in second. The diaphragm has expanded so I'm guessing I didn't get it perfectly back in the groove, I think it's good now.
