KLX 300 springs
KLX 300 springs
For those considering fork spring changes, I have installed two sets of Race-Tech KLX 300 springs in KLX 250S bikes. They fit good when used with two preload spring washers in each side. There is 1/2" uncompressed difference in height when compared to the 250, but once installed with proper preload there are no problems. Install only took about 20-30 minutes per bike excluding distractions (two year old). I weigh 165 and used .42 kg springs andit feelsgreat now. Cost was $109 and free shipping from my dealer.
I'm sure Moto-Pro would have been just as good or better, but it was easier for me to order the Race-Tech springs from my dealer. I would've ordered from Moto-Pro if I could've done it online at the time.
RE: KLX 300 springs
Yeah, I'm all about who can give me immediate results once I'm ready to make my order. Thanks for the info. I'm sure there are a lot of people who will benefit.
I will eventually address the suspension, but because I weigh-inat 140lbs, it's not an immdediate need. My butt has the biggest vote right now, so I think a seat will be on order soon. The seatshould compliment the Clark 2.9gal tank nicely
RE: KLX 300 springs
I'm the other set of springs that Wes installed. Being a bit heavier at 185 pounds, I went with the .44 kg spring rate.
What a difference it makes! The gentle wallowing that the bike did at speed on dirt roads is gone. I can actually come up fast to a 90 degree corner on a dirt road and pitch it sideways and setup a nice powerslide coming out of the corner. Before, the front end would want to turn in too much or just kind of 'crab' through the corner. It felt like a highside waiting to happen.
Trail riding is better too. I don't feel like I'm going to bottom out on big ruts anymore and it's a lot less jarring through the handlebars. As long as you're doing your part with weight transfer, etc, the front will stick where you put it. (Assuming you have a good front tire for the dirt .)
It feels better on the pavement too. Fork dive is greatly reduced and the bike feels a lot more settled in fast sweepers. It's a lot more 'flickable' too. In quick left/right transitions, the forks don't pump anymore.
Thanks for the help Wes!
