KLX-300 front wheel?
Will a KLX-300 front wheel fit our KLX-250S's?
I would like to mount a true offroad front tire on a wheel and keep a street tire on the other. I think this would be ~$250 cheaper then getting an Excel front wheel.
If I go with an Excel, what sort of total cost am I looking at? Can I get a complete front hub and add a disc brake and have someone lace up the Excel rim?
Thanks!
Thanks!
For reference, you can take off a grease seal ring from the 250 speedo and it still works. It may not fit on the wheel without removing it. I do this on my 09 250s when the SM wheels are mounted.
The hubs were from a KLX650 I believe so it's highly possible you will run into the same issue, with an easy fix.
I believe it is from a 2007 KLX-300. It looks near brand new. The tire on it is barely worn and stock. I'm guessing the previous owner put SuperMoto wheels on and this one has just been sitting around.
Sid Post
04-22-2008 05:26 PM
tennisman
01-29-2007 01:20 AM
